0.83: scanning does not work
Analitik
Post by Analitik »
В версии 0.83 пункты меню "Файл" - "Выбрать TWAIN-совместимое устройство" и "Сканировать..." не работают - их выбор не выполняет никакого действия. Проверено на двух компьютерах с Windows 10 Home 64-bit.
Menu items "File"-"Select TWAIN source" and "TWAIN scan" don't work - their selection does not perform any action. Tested on two computers with Windows 10 Home 64-bit.
Re: v0.8.3: scanning does not work
Analitik wrote:Menu items "File"-"Select a TWAIN-compatible device" and "Scan..." dont work - their selection does not perform any action. Tested on two computers with Windows 10 Home 64-bit.
Currently TWAIN is only supported in XnView MP 32-bit, which you can run on 64-bit Windows, and if you wish have installed at the same time as XnView MP 64-bit...
Analitik
Post by Analitik »
Большое спасибо за информацию!
Thank you very much for the information!
