EXIF export
By hand---
- You can do this already “by hand” as a workaround :
• Select all / some needed items on the EXIF info page,
• Make a right-click on the selection,
• You get a local menu (just one entry) «Copy to Clipboard»,
• Then, paste the Clipboard content in any text-editor…
- Of course, a direct command should be great, but it'ld bind to have a stated text-editor as an option…
- However, I support this idea.
Re: EXIF export
For exporting EXIF info, youseberri wrote:it will be usefull to export exif as textfile
1 - Open your image
2 - Select "Edit > Metadata > Export EXIF as text..."
There is no Batch export for exporting EXIF info of multiple images, so you have to perform the above for each single file.
Lesmo16
Re: EXIF export
But this only available in Viewer mode!helmut wrote:For exporting EXIF info, youseberri wrote:it will be usefull to export exif as textfile
1 - Open your image
In Browser mode there is only "Edit IPTC data ..."!
And that leads me to a new request.
Everyone who believes in telekinesis, raise my hand!
