XnView 0.84 beta 3
In draw tool, when clicking (without moving the mouse) to insert a line on the image canvas, a big rectangle appears.
1. Start draw tool
2. Select "Line" shape.
3. Set arrows to "None" (no arrows)
4. Set line thickness to "20"
5. Click on the image to insert a line (make sure you keep right mouse button pressed and don't move the mouse when clicking)
--> You will see a large rectangle. When moving the mouse (still right mouse button pressed) the large rectangle disappears.
I'd considered this as a minor, but a bit irritating issue.
0.84b3: Draw tool: Large rectangle when inserting line
Re: 0.84b3: Draw tool: Large rectangle when inserting line
i can't reproduce, could you post a screenshot?
right, when the 2 points are the samehelmut wrote:I found out that the important bit is that you draw multiple lines. The problem appears with the second, third, ... line.xnview wrote:i can't reproduce, could you post a screenshot?
Yes, and Zoom must be 200%, 400%, 800%, or 1600%.xnview wrote:right, when the 2 points are the samehelmut wrote:I found out that the important bit is that you draw multiple lines. The problem appears with the second, third, ... line.xnview wrote:i can't reproduce, could you post a screenshot?
Looks like this has been fixed in v0.84 final. ->Closed
