Opens in a new folder?
Mklio
Post by Mklio »
When I double click on a zip folder in Xn classic, it opens the file with xn browser but in xn mp, it opens the file in a new windows folder. Is there any way to stop this?
Erixx haxx
Re: Opens in a new folder?
Post by Erixx haxx »
Hello:
This should probably be posted in the classic forum, but I see why you put it here and depending if this will fix your issue.
Can you check in classic for:
-Options>> keyboard/mouse>> open action (browser) tab.
See what is selected for archives. should be >> open in xnview or the app you have set to open it's extension.
I also believe you need classic full version or the zip dll to open archives in classic.
Mklio
Post by Mklio »
That's how I have it set up in classic, but I want to use Xn MP and that option isn't in Xn MP.
Erixx haxx
Hello:
I don't think that feature has been put into MP as of yet. I think it's still planned though.
Mklio wrote:That's how I have it set up in classic, but I want to use Xn MP and that option isn't in Xn MP.
Archive in browser is not yet supported
