Shear Applied To Selection Makes Black Rectangle
TheEvilHammer
Post by TheEvilHammer »
When I try applying the shear effect to a selection of a picture, the result is that the entire selection rectangle is filled with black. If I apply the shear effect to the entire picture (with no selection), it works fine. But it doesn't seem to work correctly when applied to a selection. Has anyone else seen this?
Re: Shear Applied To Selection Makes Black Rectangle
TheEvilHammer wrote:When I try applying the shear effect to a selection of a picture, the result is that the entire selection rectangle is filled with black. If I apply the shear effect to the entire picture (with no selection), it works fine. But it doesn't seem to work correctly when applied to a selection. Has anyone else seen this?
Yes right :bugconfirmed:
