transparency corruption on certain files
CreativeWorld
Post by CreativeWorld »
certain files with transparency have a corrupt output
attached a sample on sendspace
https://www.sendspace.com/file/bojzyl
Re: transparency corruption on certain files
The input file (32-bit PNG) has to be “flattened” before converting it to JPEG format: Image » True Colour
CreativeWorld
I see, thank you
but is there any point not converting the color depth automatically?
CreativeWorld wrote:but is there any point not converting the color depth automatically?
I consider this to be a bug. (Manually reducing the color depth is just a workaround.)
Is it fixed in 2.39?
xnview wrote:Is it fixed in 2.39?
Yes, fixed in v2.39 :-o :-)
