Alpha Channel and 24-bit BMP images
Kattmandu
Post by Kattmandu »
Is it possible to permanently turn off "Use Alpha Channel" for the View mode like there is for the Thumbnail mode? I have 24-bit BMP images with transparency that do not display the same as they do in Paint or similar image viewers. The transparency displays as grey. Ctrl+H turns it off for the session but it is turned back on when XnViewMP is closed and re-opened.
Re: Alpha Channel and 24-bit BMP images
sorry but currently no way
Perhaps you can set the two colours of the checkboard pattern both to white (or any other colour) and thus achieve what you want:
Menu "Tools > Settings" | Category "View" | [x] Use checkboard pattern as background
Just an idea...
EDIT: From what I can see Paint uses the palette colour which is used as transparent colour for palette-indexed PNG files. So the background colour displayed in Paint is not fixed but depends on the opened PNG image.
