Icons In The Tabs
TheEvilHammer
Icons In The Tabs
I've noticed that each "view" tab shows an iconified version of the current image and the browser has its own tab icon. Is there any way to change the personalized "picture-iconified" icons to a stock icon? Or better yet, is there a way of disabling tab icons altogether?
Lesmo16
@TheEvilHammer:TheEvilHammer wrote:Or better yet, is there a way of disabling tab icons altogether?
Yes, of course - in xnView is almost everything adjustable!
Un/Check: Options -> Folder Tabs -> "No thumbnail in folder tab"
This setting takes effect with every new folder tab or after restarting xnView.
@xnview:
Little bit inconsistant, right?
I think you'll fix that
Everyone who believes in telekinesis, raise my hand!
