0.83: Operations on categories slow
jadO
I don't know if it is a real bug. But using the sidecar filter categories, it seems to be extremely slow.
Re: Categories slow
what do you mean by sidecar filter categories??jadO wrote:I don't know if it is a real bug. But using the sidecar filter categories, it seems to be extremely slow.
jadO
Re: Categories slow
I mean the category filter pane. Anything related to it is slow: Selecting multiple, deselection, creating thumbnails with having categories selected.xnview wrote:what do you mean by sidecar filter categories??jadO wrote:I don't know if it is a real bug. But using the sidecar filter categories, it seems to be extremely slow.
Re: Categories slow
even selecting a rating?
m.Th.
Re: Categories slow
jadO wrote:I mean the category filter pane. Anything related to it is slow: Selecting multiple, deselection, creating thumbnails with having categories selected.xnview wrote:what do you mean by sidecar filter categories??jadO wrote:I don't know if it is a real bug. But using the sidecar filter categories, it seems to be extremely slow.
1. How many categories do you have selected? 5? 10? 100?
2. How many categories do you have in total? 100? 500? 1000?
3. In Tools | Settings | Catalog | Memory usage for database engine: - what value do you have?
4. What storage do you have? HDD? SSD?
5. How much memory do you have?
m. Th.
m.Th.
Re: Categories slow
xnview wrote:even selecting a rating?
...perhaps separate indices on ImageID and (especially) TagID would help in table TagsTree... - but this needs real benchmarking on his system...
m. Th.
jadO
Re: Categories slow
Yes everything to select in that pane slows down XnViewMP.xnview wrote:even selecting a rating?
1. Depends: 1- 20m.Th. wrote:1. How many categories do you have selected? 5? 10? 100?
2. There is no easy way to count. Maybe 300-500
3. 500 MB
4. HDD
6. 12 GB
m.Th.
Re: Categories slow
jadO wrote:Yes everything to select in that pane slows down XnViewMP.xnview wrote:even selecting a rating?
3. 500 MB
4. HDD
6. 12 GB
Hmmm... it shouldn't make any difference. I don't know what SQL Pierre uses - he should use a (NOT) IN predicate and put the values of TagID as numbers in there - this is the fastest way.
Besides that, a common problem (dunno if it is fixed now) on XnView and other programs are the so-called 'offline files' or 'hard-to-reach files'.
Let's say that I have cataloged some files which I don't have access anymore (the volume went offline - think a unplugged external USB disk) or a slow media - for example a slow (WiFi?) LAN share, a clogged disk etc.
When I do my filter, the program grabs ALL the files which met the condition, regardless of directory (do you use the filter with the scope ALL or 'This Directory Only'?) hence it can try to show offline files or hard-to-reach files which would slow all the system.
Questions
1. (again): Do you use the filter with the scope "ALL" or "This Directory Only"'? (it is located in the 'Match' drop-down at the top of the pane)
2. If you do such a filter how many photos do you get? 10? 100? 1000?
3. Which file format?
4. How big are the files on average?
m. Th.
Re: Categories slow
Is it possible to have the database file?jadO wrote:Yes everything to select in that pane slows down XnViewMP.xnview wrote:even selecting a rating?
jadO
Re: Categories slow
No.xnview wrote:Is it possible to have the database file?
Re: Categories slow
not easy to understand what's happenedjadO wrote:No.xnview wrote:Is it possible to have the database file?
m.Th.
Re: Categories slow
You didn't respond to my last message (4 questions there)...jadO wrote:No.xnview wrote:Is it possible to have the database file?
m. Th.
