What does this option do:
Tools -> Options -> Intall -> Add XnView as application for USB events?
When I plug in my camera or my card-reader, windows shows a dialog, where I can select an application to be started. But XnView doesn't appear in this dialog, even when above option is checked.
USB events
Re: USB events
XnView should be visible in this dialog if the option is enabled. Which system do you have? Other users with the same problem?raga wrote:What does this option do:
Re: USB events
My system is Win XP professional SP2.xnview wrote:XnView should be visible in this dialog if the option is enabled. Which system do you have?
After looking arround in the registry, I found some difference between Xnview and other applications:
XnView adds its entry to the key
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\StillImage\Registered Applications
The application that are listed after plugging in my camera add their entries to the key
HKLM\SYSTEM\CurrentControlSet\Control\StillImage\Events
The application that are listed after plugging in my card reader add their entries to the key
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\AutoplayHandlers
Re: USB events
Yes, info that found for Still Image, is to set this keyAnonymous wrote:My system is Win XP professional SP2.xnview wrote:XnView should be visible in this dialog if the option is enabled. Which system do you have?
On my Win2K, i have no key here:
raga
Seems to work different in different windows versions:
http://groups.google.de/group/microsoft ... d51a8ab56e
raga
Here are two more links - don't know whether they are helpful:
http://msdn.microsoft.com/library/defau ... kclsid.asp
http://msdn.microsoft.com/library/defau ... rogram.asp
dadaniel
I can't say it definitely. I don't know much about windows registry.
But please try out Photocopier Pro from nicocuppen.com
http://www.nicocuppen.com/product.php?p ... 0&prodID=7
It registers correctly.
