Sorry for a trivial question, but is it possible to disable the built-in movie player?
When I double-click on the file, I would like the associated program (movie player) to play the file.
Currently I need to use the right mouse drop down menu to select the program or use the keyboard (F3) to play the file.
Disable built-in Movie Player?
Erixx haxx
Re: Disable built-in Movie Player?
Settings>> File list>> Custom filter
Thanks!Erixx haxx wrote:Hi,
(not intuitive to look there...)
It would be great to have an option there to specify additionally a path to the application that should be opened.
