Working with files from multiple folders
CreativeWorld
Post by CreativeWorld »
Should be extremely usefull to list, rename and open files from multiple folder, particularly to compare images.
It was a features I saw very long time ago in AcdSee.
m.Th.
Re: Multiple Folder
Post by m.Th. »
Yes - sure. The feature is already here. However the GUI doesn't surface it as it should. See here:
http://newsgroup.xnview.com/viewtopic.php?f=62&t=30017
...there is a post of myself with a screenshot.
m. Th.
m.Th.
Re: Multiple Folder
Post by m.Th. »
Found it! (ok, Pierre shown me... :)
It shows all the files from subfolders.
m. Th.
