Use RAISR or SRCNN for image resize for viewing
Jou
Post by Jou »
The current "high quality" rescaler also makes the images a bit blurry when scaling down by just 10%.
Question is: Which algorithm is used anyway? Bicubi? Bilinear? Lanczos?
What about the google RAISR algorithm at https://research.googleblog.com/2016/11 ... chine.html and SRCNN algorithm at http://mmlab.ie.cuhk.edu.hk/projects/SRCNN.html
Any chance you'd include one of them?
A comparison between those two at https://thestack.com/wp-content/uploads ... amples.jpg shows IMHO not much difference between RAISR and SRCNN the are both good.
Gaming in 4k / 6k / 8k / 15k / 16k? Yes! https://joumxyzptlk.de
m.Th.
Re: Use RAISR or SRCNN for image resize for viewing
Post by m.Th. »
Jou wrote:The current "high quality" rescaler also makes the images a bit blurry when scaling down by just 10%.
...your title says "for viewing"... this changes the things a lot: we do not need the best quality kernel but the best speed 70%/quality 30% proportion ratio.
Perhaps the best thing would be to add (if Pierre wants) these algorithms in the resize kernel list which is surfaced in Browser Tab in Tools | Batch Convert | Resize or in Single Image Tab in Image | Resize and perhaps(?) use the same list in Tools | Settings | View | High zoom quality [sic] - btw. it should read High Quality Zoom.
What setting do you have for "High Zoom Quality" setting mentioned above? Did you tried the other values?
m. Th.
