Hi, I'm running Xnview on Ubuntu 14.04. Some view settings are not persistent. For instance, if I hide the title bar, then view something full screen, the title bar will come back. Also, If if iconify tabs, then restart xnview, the tabs are no longer iconified.
Maybe I can hack the ini file to make these persistent?
Ubuntu: Making view settings persistent
Re: Ubuntu: Making view settings persistent
ok, i'll check on unbuntu3x5 wrote:I'm running Xnview on Ubuntu 14.04. Some view settings are not persistent. For instance, if I hide the title bar, then view something full screen, the title bar will come back.
you means Settings>Interface>Tabs>Display?Also, If if iconify tabs, then restart xnview, the tabs are no longer iconified.
3x5
Pierre, thanks for the reply and for the excellent program. If I go to the tab settings, I can choose thumbnail, icon, or none, but this is different than when I right-click on the tab area and click 'iconify tabs'. This removes the filename from the tab and you just have the thumb or icon left.
Erixx haxx
http://newsgroup.xnview.com/viewtopic.p ... 55#p137555
right iconify setting is not stored3x5 wrote:Pierre, thanks for the reply and for the excellent program. If I go to the tab settings, I can choose thumbnail, icon, or none, but this is different than when I right-click on the tab area and click 'iconify tabs'. This removes the filename from the tab and you just have the thumb or icon left.
