How to remove folder images
3x5
Post by 3x5 »
I saw in the UI-less settings that I can change the color of folders. This is good because I'm using the dark theme and I want the folders to just appear as gray boxes. I was able to go into UI-less settings and make all 5 bg colors the same, giving me a gray box. However, there is still a graphic at the top that shows a folder tab with a white background. I have attached an example.
I looked in /opt/XnView/UI but I didn't see anything there that looked like that folder image. Does anyone know how I can remove that, so I can get the look I want? Thanks.
Re: How to remove folder images
Does this…
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=115135#p115135]Change colour of background behind the thumbnails[/url]) wrote:
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=112326#p112326]Re: Xnview MP Dark UI Enhancement[/url]) wrote:
Evil_D wrote:How to make the color of the number 1 is the same as the color of number 2?
http://img402.imageshack.us/img402/5525/ghl.png
Changing the background color of the thumbnail panel (Tools » Settings... » Browser » Thumbnail » Appearance » Thumbnail cell » Appearance » Background) doesn't take immediate effect behind/under the folders :bugconfirmed:
As a workaround, you can force MP to redraw the folder thumbnails by changing the thumbnail size (View » Thumbnail size...).
… fix the issue, 3x5?
