0.84: Folder tree not updated when deleting folder
When deleting a folder in the file list of XnView, the folder tree isn't updated.
Note: This problem may be related to topic 0.83: Tree And Browser Sync Issue.
1. Start XnView
2. Activate "Folders: Visible" in Tools » Settings... ] Browser » File list ] Custom filter and confirm settings.
3. In tree pane of XnView create a new folder "A".
4. In file list, delete the folder that you've just created.
:arrow: Folder "A" is still visible in the tree pane. :bug:
Expected: Folder "A" should no longer be visible in the tree pane.
5. Select "View » Refresh" or press F5 key to refresh.
:arrow: Nothing happens. Folder "A" is still visible in the tree pane. :bug:
Expected: Tree pane should be refreshed and folder "A" should no longer be visible in the tree pane.
Re: 0.84: Folder tree not updated when deleting folder
Could someone else please try to reproduce my above problem?
I can reproduce it for empty folders.
XnTriq wrote:I can reproduce it for empty folders.
Thank you for reproducing and confirming the problem, XnTriq.
O.k., thank you, I can also reproduce the problem. Issue 1073 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.85 beta 1. Please check and confirm the bug fix here.
Confirmed fixed in 0.85 beta 1.
