currently I have to set the "format settings" global und can only change them on the fly with the "Export" option.
But: I often crop images and use the function "Save selection as...". After choosing the folder/filename and pressing "Save" I want to set the format-Settings as in "Export"-dialog.
You can implement a new setting "File settings after save". If I choose JPG in Save-As-Dialog, the format-setting shows me only the settings for JPG.
Best regards,
Tom
Format Settings after "Save as" dialog
Re: Format Settings after "Save as" dialog
Are you talking about this?
http://newsgroup.xnview.com/viewtopic.php?f=82&t=32970
Sirio
YesAre you talking about this?
