UI: "Reset to standard" buttons: Disabled when standard
It's good to have the "Reset to standard" buttons in various dialogs like "Enhance colors..." dialog. Currently, these buttons are quite striking and distracting due to their orange colouring.
Suggestion:
The "Reset to standard" buttons should be grey and inactive if their value is the standard value and get active whenever their value is changed and no longer the standard value. This way the user can see at first glance, which settings are no longer standard plus the problem because of their striking colour is solved.
