0.72 Linux: xnviewmp touches folder (changes files' time)
Bill_Baklushi
Hello.
I like xnviewmp as good linux analog of Acdsee . I used version 0.64 ok. But version 0.72 sometime corrupts file time, change it to current time.
I noticed that it happens when closed xnviewmp hangs long time in the background.
I often use sortinng by time, so i want to disable this unwanted behavior.
UPD: It happened about 3-4 times in the nov and dec 2016.
Thumbnail caching is disabled. Images located in NTFS and EXT4 volume if it's important.
OS: xubuntu 14.04 x64
What setting i need to disable?
Or if it's bug - is it fixed in newer version?
Last edited by Bill_Baklushi on Sun Feb 05, 2017 9:55 am, edited 4 times in total.
Re: 0.72 Linux: xnviewmp touches folder (changes files' time
Thank you for registering to the forum and your request, Bill. Before trying to analyze your problem I'd ask you to update to the latest version of XnView MP, which is version 0.84.
Bill_Baklushi
helmut wrote: Before trying to analyze your problem I'd ask you to update to the latest version of XnView MP, which is version 0.84.
You wrote about unwanted and unexpected updates of file time stamps. It can well be that the problem no longer persists in the latest XnView MP version; so a program update is the way to go.Bill_Baklushi wrote:helmut wrote: Before trying to analyze your problem I'd ask you to update to the latest version of XnView MP, which is version 0.84.
Bill_Baklushi
ok. I installed v0.84helmut wrote:Thank you for registering to the forum and your request, Bill. Before trying to analyze your problem I'd ask you to update to the latest version of XnView MP, which is version 0.84.
It seems that this version correctly disappers from process list when closed and it doesn't eat cpu time when it idle.
I'll stay v0.84 open on test folder tonight
Good. Let's see whether the update really solved your problem - please let us know tomorrow abot your test result.
Bill_Baklushi
I didn't reproduce this bug.
Bill_Baklushi
What is the file with extension .XnViewSort in the image folder?
Good. Problem solved.Bill_Baklushi wrote:I didn't reproduce this bug.
In XnView Browser you can sort files in a folder manually by dragging them around. This manual or custom sort order is saved in the file ".XnViewSort" (on Windows this file is a hidden file).Bill_Baklushi wrote:What is the file with extension .XnViewSort in the image folder?
Bill_Baklushi
OMFG. Bug was reproduced now.
I don't sure that xnviewmp is guilty of this.
There xnviewmp and Tor Browser hangs, and after some time Krusader (2.4.0-beta3) hangs too.
Image folder is Tor Browser's "Downloads".
xnviewmp and krusader disapears when i kill tor browser's process.
UPD. Files was touched recursively.
There is about 10GB of files (basically jpg and mht).
about 10000 files.
about 10000 files.
Thank you for your update, Bill. Would be good if you could track down which application causes the problem. ATM, I have little idea why XnView should update thousands of files.Bill_Baklushi wrote:OMFG. Bug was reproduced now.
