Modeless batch
obelisk
Modeless batch
I'd like to run a batch convert, and get back to browsing and doing other stuff. You should be able to open multiple windows too.
m.Th.
Re: Modeless batch
OOOOOHHHH!!!
The white unicorn!
Already discussed here: http://newsgroup.xnview.com/viewtopic.php?f=60&t=29204
Hint: Meanwhile you can keep the SHIFT pressed when you click on "Batch Convert" menu option...
The white unicorn!
m. Th.
