Hitting DEL key while renaming file deletes file [Bug]
Post by Guest »
I just tried to rename a file. I selected it in the browser, hit F2, and started editing the name. I wanted to delete three characters and thus hit DEL three times. Result: three deleted images. Not quite what I wanted.
Re: Hitting DEL key while renaming file deletes file
Anonymous wrote:...I selected it in the browser, hit F2, and started editing the name. I wanted to delete three characters and thus hit DEL three times. Result: three deleted images....
You're right, a bad bug :bugconfirmed: in XnView 1.68. The same when you press Esc key to abort file renaming: Instead of aborting renaming, the browser is closed. Think Pierre will fix this, soon.
Yes :bugconfirmed: :? , a 1.68.1 will available asap!
Post by Guest »
Thanks! Looking forward to the fix and trying to keep my fingers away from the DEL key in the meantime.
The XnView version with the bug fix (1.68.1) is available for download, see XnView 1.68.1
