0.84: Context menu for toolbar not consistent
In XnView 0.84 the context menu for the toolbar is inconsistent:
- Order of the menu entries doesn't reflect the typical order on the screen.
- Info pane has only entry "Info" while Data pane has all (sub) entries
- (English) naming of data panes doesn't match the namings in "View > Data pane >".
Current context menu:
Info
Categories Filter
Folders
Favorites
Categories
Category sets
Toolbar 1
Customize toolbar...
Detach preview panel
Suggestion:
Toolbar
Folders
Favorites
Category Filter
Categories
Category Sets
Histogram
EXIF
IPTC-IIM
XMP
Exiftool
GPS
Re: 0.84: Context menu for toolbar not consistent
It's an automatic context menu filled by Qt with all panels, i add to it only 'Customize toolbar'&'Detach preview panel'
xnview wrote:It's an automatic context menu filled by Qt with all panels, i add to it only 'Customize toolbar'&'Detach preview panel'
O.k.. But at least the naming in View » Data pane and View » Info pane should match the tab titles:
[View » Data pane »] Filter --> Categories Filter
[View » Data pane »] Sets of Categories --> Category Sets
ok :)
