cache issues
loth
cache issues
Post by loth »
hi,
i know, there are some threads about caching and other cache optimizing issues.
maybe, if this report isnt a double-entry, you could merge this post with them, because 1)+2) are still not workin in 1.80.3.
1)
options->browser->cache
click on "cached directories" or "images" or "size" to sort the entries.
it will not sort.
found at: http://newsgroup.xnview.com/viewtopic.php?t=2402
2)
click on "optimize".
after optimizing your cache, you will see folders that doenst exist anymore on the harddrive,
but the entries "cached directories" "images" "size" are showing "P:\pics\folder" "24" "185.75KB" or something...
while other entries show images "0" and size "26bytes" where a lot of pictures are in this folder.
isnt optimizing deleting all the folder-entries xnview doesnt need anymore?
found at: http://newsgroup.xnview.com/viewtopic.php?t=3030
loth
Re: cache issues
loth wrote:hi,
1)
it will not sort.
2)
I think that for next BIG release, i'll change the way to cache thumbnails, and i'll use a true DB for that.
stausi
Post by stausi »
Hi Pierre,
What i am missing is the possibility to set a maximum size on the cache folder.
Regards,
Martin
Dreamer
Post by Dreamer »
stausi wrote:What i am missing is the possibility to set a maximum size on the cache folder.
Regards,
Martin
Hi Martin,
welcome to the forum!
Please check this topic - Limit Cache Option.
duckjibe
Post by duckjibe »
The main problem in cache from my point of view is speed.
When I enter a directory where there are a lot of images ( >500)
the PC gets stuck for fews seconds. This is annoying.
Xnview shall just display current images & update in background.
Easy to say but maybe complex to do !
Here and there…
:arrow: duckjibe
:) Hello !
…Xnview shall just display current images & update in background. …
- Please, just give a look here and next…
- This seems really needed.
:mrgreen: Kind regards,
