0.84: # of object(s) selected doesn't clear properly
vertigo
Post by vertigo »
XnView: MP 0.84 x64
OS: Windows 7 - 64 bit
Effect: When clearing / unselecting / deselecting a selection of files, the count of files selected doesn't change / clear / reset.
1. Select one or more files in browser
2. Click in empty space to clear the selection
3. The # of selected files in the status bar will still show the number you had selected (it doesn't reset / clear)
4. Select one or more files to update the number
Actual behaviour (bug): The status bar count of # of selected files doesn't update when clearing the selection
Expected behaviour: When clearing the selection, the # selected in the status bar should read zero (0)
Re: 0.84: # of object(s) selected doesn't clear properly
Reproduced.
O.k., thank you, I can also reproduce the problem. Issue 1108 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.85 beta 1. Please check and confirm the bug fix here.
vertigo
Post by vertigo »
Confirmed fixed.
