As requested, I'm copying this from a bug thread over here for proper separation/tracking:
Implement changes to make use of the ample status bar space and have it show # of supported files / # of files / # of folders / total # of objects, and which of these show and in which order could be configured by the user.
Also, having total # of objects / # of objects selected followed by the word "selected" seems backwards to me. Instead of reading 200 object(s) / 3 object(s) selected (which at first made me think it was a bug), maybe have it say one of the following:
3 object(s) / 200 object(s) selected
3 object(s) selected / 200 objects(s)
3 / 200 object(s) selected
Furthermore, it seems to me it shouldn't be that difficult to have the code recognize if the number is =1 or /=1, and adjust whether it says object or objects accordingly:
If var = 1 Then Display var + "object"
Else Display var + "objects"
End If
Finally, all the info in the status bar kind of runs together. It could use a bit more spacing and maybe colored separators to help break it up.
Status bar tweaks
Jump to
- General
- ↳ Info & Forum
- ↳ XnView - FAQ
- ↳ Miscellaneous
- XnView MP
- ↳ MP - Announcements
- ↳ MP - General Support
- ↳ MP - Bug reports
- ↳ New
- ↳ Reproduced - TODO
- ↳ Fixed in next version
- ↳ Retest
- ↳ Postponed
- ↳ Closed/Resolved
- ↳ MP - Suggestions
- ↳ MP - General [Français]
- XnView Classic
- ↳ Classic - General Support
- ↳ Classic - Bug Reports
- ↳ Classic - Suggestions
- ↳ Classic - General [Français]
- XnView Family
- ↳ XnConvert
- ↳ XnResize
- ↳ XnRetro, XnSketch, ...
- ↳ NConvert
- ↳ XnView Shell Extension
- ↳ Android & iOS: XnPhotoFx, XnRetro, XnSketch, ...
- ↳ XnView Pocket
- ↳ GFL SDK
- Contribution
- ↳ Customization
- ↳ Documentation
- ↳ XnView MP - Translation
- ↳ XnView Classic - Translation
- ↳ Testing - Closed/Solved
- ↳ 1.96 Testing - Feedback
- Archive
- ↳ XnView Un*x
- ↳ XnView Mac OS X
- ↳ Classic - Resolved Bugs & Requests
- ↳ MP - Resolved Bugs & Requests
- ↳ MP – Beta Testing
- ↳ New
