How to rotate file from multipage tiff
punith8626
Post by punith8626 »
I need to extract particular page from multi page tiff and rotate the same page in single command how do I do it ?
Re: How to rotate file from multipage tiff
punith8626 wrote:I need to extract a particular page from a multi-page tiff and rotate the same page in a single command how do I do it ?
If you include the following term in your code to extract the desired page I think you should get the result you want:
-rotate degrees   : Rotate
Where 'degrees' is the angle you want.
