0.84: Selection: Swapping h/w doesn't update status
XnView: MP 0.84
OS: Windows 7 - 64bit
When swapping height/width of the selection by pressing "W" key, values for height & width in the statusbar aren't updated.
Effect: Irritating user interface (minor)
1. Open an image in Viewer of XnView
2. Select an area of the image
3. Press "W" to swap height/width of the selection
Actual behaviour (bug): Height/width of the selection is swapped. Status bar still displays height/width of the selection before swapping. :bug:
Expected behaviour: Height/width of the selection is swapped. Status bar is updated.
Re: 0.84: Selection: Swapping h/w doesn't update status
O.k., thank you, I can also reproduce the problem. Issue 1118 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.85 beta 1. Please check and confirm the bug fix here.
Problem is partly fixed in v0.85 beta 1:
Status bar is updated. (correct)
Position is set to X:0 Y:0 ( wrong :bug: )
will be fixed in beta 2
This problem is supposed to be fixed in XnView MP 0.85 beta 2. Please check and confirm the bug fix here.
Confirmed fixed in 0.85 beta 2. There is still something wrong with the X,Y position but I'll post a new bug report.
