OS: Windows 7 - 64bit
Swapping height/width of the selection by pressing "W" key does no longer work after pressing Tab key.
Effect: Irritating user interface (minor)
1. Open an image in Viewer of XnView
2. Select an area of the image
3. Select Edit Selection - Swap width & height
4. Press 'Tab' key two times
5. Press 'W' to swap width & height of selection
Actual behaviour (bug): Nothing happens
Expected behaviour: Height/width of selection is swapped.
Note:
If the problem shouldn't occur, press Tab, one more time and try swapping selection by pressing 'W', again.
