.DTX Format Support
viktor
.DTX Format Support
Post by viktor »
Lithtech DTX is the image format that the game-engine "Lithtech" is using.
The engine is from 1998, but is still used from time to time today.
There is a Photoshop plugin (8bi) which can read the DTX files, I will provided a download link below if that would help to add support the format.
Photoshop plugin: https://www.mediafire.com/?87zblqgv7v6b085
Source code for Photoshop Plugin: https://www.mediafire.com/?9wmprus2eu7c2ew
Another program that can read and convert DTX files:
http://www.mwgfx.co.uk/graphix.htm
m.Th.
Re: .DTX Format Support
Post by m.Th. »
I think that Pierre would need some samples too... :)
m. Th.
viktor
Post by viktor »
Here is 10 different DTX files, thanks alot for the quick response! :wink:
Download link: https://www.mediafire.com/?t4l2mii5pwem02c
viktor wrote:Here is 10 different DTX files, thanks alot for the quick response! :wink:
Thank you for the sample files, viktor. Let's see whether Pierre can add support for the .DTX format.
