0.84: Join images: Wrong alignments for horizontal joining
XnView: MP 0.84
OS: Windows 10 - 64bit
When joining images horizontally, the user can choose the vertical alignment for the images. The alignments available in the drop down list are left / center / right which are horizontal alignments.
Effect: Irritating user interface
1. In XnView browser select several image files
2. Select Create » Join Images...
3. In "Join Images" dialog, choose "Horizontal" layout.
Actual behaviour (bug): In the "Alignment" drop-down list there is left/center/right. :bug:
Expected behaviour: In the "Alignment" drop-down list there is top / center / bottom.
Note: This bug was found by user "Hans H.".
Re: 0.84: Join images: Wrong alignments for horizontal joini
if in list, i use 'Left-Top' & 'Right-Bottom' is it good?
xnview wrote:if in list, i use 'Left-Top' & 'Right-Bottom' is it good?
I think entries should be
"Left / Top"
"Center / Center"
"Right / Bottom"
I think the interface would be even clearer if entries of the "Alignment" dropdownlist would depend on the type of joining (horizontal/vertical).
This problem is supposed to be fixed in XnView MP 0.85 beta 1. Please check and confirm the bug fix here.
"Left / Top"
"Center / Center"
"Right / Bottom"
This is the way it's displayed in v0.85 beta 1. Confirmed fixed
helmut wrote:I think the interface would be even clearer if entries of the "Alignment" dropdownlist would depend on the type of joining (horizontal/vertical).
This hasn't been implemented, yet. Perhaps in a future release...
