I would like to use an automated process, but I am getting.
PROMPT: The ' Delete original' option is enabled, do you want to continue?
can I remove this prompt, it seems redundant since I checked the delete box.
Remove delete prompt
Re: Remove delete prompt
currently no, the dialog box was added to be sure that checkbox was not clicked accidentally
A case for 'Do not ask again' ??xnview wrote:currently no, the dialog box was added to be sure that checkbox was not clicked accidentally
