When I rename a folder (from the Folder Tree View) it doesn't show the contents (thumbnails) when I move to another folder and come back to the renamed folder.
1. Select a folder in the Tree view and note the thumbnails being shown
2. Right-click and choose Rename
3. Rename the folder (in my case I append a description to the folder, which is initially yyyy-mm-dd)
4. Select another directory, and note the thumbnails
5. Select the first directory, the one you just renamed, and notice the thumbnails
Result:
After step 5 you'll see that the thumbnails shown are still those from the directory in step 4.
0.72 Linux: Contents not shown after renaming
schultzter
Version 0.72 x64 (Dec 19 2014) on Arch Linux
Headed for the second star to the right and straight on 'til morning...
schultzter
Re: Bad implementation of the folder rename
I've also noticed I can't rename a directory twice. Once the directory has been renamed the option to Rename (and others) is disabled. This is an issue if I make a mistake when initially renaming the directory.
See:
See:
