the first time that I have a problem with XnView:
after installing 2.39 some of the preferences will not be accepted. Even after changing, XNV is starting with its own (one example thumb background colour).
horst
2.39 does not keep all preferences
Re: 2.39 does not keep all preferences
Thank you for your problem report, horst. This sounds like a permission problem. Could you please check where XnView saves its settings? The full path of the .ini files is displayed in the About dialog (menu "Info > About..."). Does XnView have permission to write into that folder?
Related topic:
- Info about XnView's settings (store & load)
Related topic:
In Tools > Options... > System integration where do you have your ini file located?siepict wrote:... after installing 2.39 some of the preferences will not be accepted. Even after changing, XnView is starting with its own (one example thumb background colour).
horst
If you are using Windows 7 or later, and have the ini located in XnView (the program folder), Windows or the Registry rather than User, access to update changes may be not be possible from a user account...
siepict
Hi Helmut, such a quick response
Strange issue (for me):
I duplicated the ini in the program folder (as BackUp) and tried to edit and save, but saving will be rejected.
I did 'the same procedure than every time', have several updates of XnView performed with this laptop with win 7 64.
I do have a valid Image of my system and will play back.
siepict
Mmhhh, ...
the old version is running again after playing back my image and doing some tests and tweaks to bring back my old layout. In the end:
The path you told me to look at is C:\Program Files (x86)\XnView\xnview.ini , but looking at that folder, there is no ini.
But I found the valid one in C:\Users\...\AppData\Local\VirtualStore\Program Files (x86)\XnView
Changing the path of the ini file in the preferences will not be accepted.
horst
horst
move the files from C:\Users\...\AppData\Local\VirtualStore\Program Files (x86)\XnView to C:\Users\...\AppData\Roaming\XnViewsiepict wrote:Mmhhh, ...
horst
siepict
It doesn't bother me too much as I now know which ini is the valid one.
horst
yes, I did so, but XnView keeps on reading and writing to C:\Users\...\AppData\Local\VirtualStore\Program Files (x86)\XnViewxnview wrote: move the files from ...
horst
