0.84 Linux: XnView MP doesn't start
<Moderator's note: This bug report has been split from another bug report>
XnView: MP 0.84 x64
OS: Gentoo Linux x64
XnView doesn't start.
Effect: Program doesn't start and thus cannot be used
amurphy7701 wrote:The latest version (tar 64bit) doesn't even start.
-> XnView: error while loading shared libraries: libpulse.so.0: cannot open shared object file: No such file or directory
I don't have pulseaudio on my system and the requested lib isn't bundled in the tar.
Re: 0.84 Linux: XnView MP doesn't start
libpulse need to be installed
xnview wrote:libpulse need to be installed
O.k., important to know.
@Pierre: Is there somewhere a list of required libaries and prerequisites for using XnView MP on Linux?
helmut wrote:@Pierre: Is there somewhere a list of required libaries and prerequisites for using XnView MP on Linux?
* bump *
* bump *
i think libpulse & gstreamer
xnview wrote:i think libpulse & gstreamer
Thank you for your answer. Does this apply for all Linux distributions or Gentoo Linux?
i don' know, i test only on ubuntu
