0.84: multiple keyword selection flaw in Edit-IPTC
CameronD
Post by CameronD »
XnView MP v: 0.84 and 0.85 beta1 (10-Mar-2017) (both 64-bit)
OS: Windows 7 Pro, x64
Description:
Cannot select multiple discrete files in Edit IPTC keywords window
To Reproduce:
  • find an image file with 3 or more separate keywords. (or create one)
  • Edit->IPTC and choose keywords tab
  • click to select one file - works
  • shift-click to select a range of files - works
  • ctrl-click to add a single file to the selection - does not work, instead a range is selected.
