MacOS Siera, XnView 0.84. I open two images and try the "pictures collections" option from print dialog. I expect the two images to appear on the preview, but instead, the same image appears two times. I can't find a way to print multiple images on a same page.
P.S. After I tried it several times, XnView started to crash when selecting 2 images to print.
0.84 MacOS: Print multiple images on one page
Quartz
Re: Print multiple images on one page
I see - the program crashes if Caption - "show information" is ticked.
m.Th.
Works for me (specs in sig). Most probably that you should send some samples to Pierre or to someone else with a Mac.
m. Th.
Re: 0.84 MacOS: Print multiple images on one page
sorry but i can't reproduce, do you select jpeg files?
