I've been trawling the forum for info on how to hide the menu... but I think all I could find was some old info on classic XnView using [Hidden] in the XnView.ini. Well, at least I couldn't make it work with MP.
So, how do I hide the menu in XnViewMP? Or use e.g. alt to toggle the menu visibility?
I'm dying for a dark, clean image viewer, which supports ~all image formats.
Is it more a theme projects perhaps?
Hide menu
Erixx haxx
Re: Hide menu
Hello:
So far I think these are what can be hid in Browser view, Viewer mode is pretty close to the same
-Title bar or window frame
-Tabs
-Tool bar
-Mini tool bar or file list bar
-Hide/Move almost any sub panel, by View>> layout>> free..
These options are under the view pull down, Tab control is inside options.
As far as: File,edit,view, menu. I don't think so
-Tabs
-Tool bar
