0.85b1: Video error dialog
Dreamer
Post by Dreamer »
XnView: MP 0.85 beta 1 64 bit
OS: Windows 10 Home 64bit
Error dialog when quickly switching mode, fullscreen > viewer.
1. Set the option in Settings > Interface > Switching mode > 2x click > "browser>fullscreen>viewer" (same for Enter)
2. Select any avi video in thumbnails view mode
3. Double click* to go to fullscreen mode and quickly double click* again, to go to viewer.
(* You can alternatively use Enter instead of double click)
Actual behaviour (bug): Error dialog with text "Error - File can't be loaded!". :bug: (file is loaded correctly in viewer, playing properly)
Expected behaviour: No error dialog.
No such a problem when quickly switching between the Browser and Viewer.
Dreamer
Re: 0.85b1: Video error dialog
Thank you for your bug report, Dreamer. Could you please check whether this problem didn't occur in 0.84 was introduced in 0.85 beta 1? (It's important to identify problems that have been introduced in 0.85 test versions.)
Dreamer
Post by Dreamer »
I can't reproduce it in 0.84 64 bit, same ini.
Dreamer
Dreamer
Post by Dreamer »
Looks fixed in beta 2, thanks, Pierre.
Dreamer
Dreamer wrote:Looks fixed in beta 2, thanks, Pierre.
I can't see any entry of Pierre.
@Pierre: Did you fix a bug, here?
Dreamer
Post by Dreamer »
Weird, I could always reproduce it in b1, now I tested with both video ini options and I can't reproduce it in 0.84, 0.85b1 nor in b2.
Perhaps multiple tabs opened might cause issues, it's not easy to reproduce.
Anyway, no bug at the moment, I'll re-post if I will be able to reproduce it again.
Dreamer
no
