0.85b1: Contact sheet: A3 and A4 don't fill in right sizes
HanVroon
Post by HanVroon »
Asume cm is selected as unit.
When selecting A4 as size, the width and height are filled in as 21,01 by 29,67. Should be 21,0 by 29,7.
When selecting A3 as size, the width and height are filled in as 29,67 by 41,98. Should be 29,7 by 42,0.
Also, the selection menu under the ...-button shows the text "A3 (29,0x42,0cm)", 29,0 should be 29,7.
Re: 0.85b1: Contact sheet: A3 and A4 don't fill in right siz
Well spotted, HanVroon! :)
This problem is supposed to be fixed in XnView MP 0.85 beta 3. Please check and confirm the bug fix here.
HanVroon
Post by HanVroon »
Tested in 0.85 beta 3, partly fixed
When unit cm is choosen, the right sizes apear when chosing A3 or A4.
When unit mm is choosen, 209,97 x 296,97 is shown instead of 210 x 297 for A4.
When unit mm is choosen, 297,04 x 419,98 is shown instead of 297 x 420 for A3.
The sizes in the menu are OK.
HanVroon
Post by HanVroon »
Tested in 0.85 beta 4: Fixed.
Now looks OK, also when switching between A3 and A4, and cm and mm.
