0.85b2: Contact sheet: Field 'Height' in wrong tab order
XnView: MP 0.84 - 64 bit
OS: Windows 10 - 64bit
When tabbing through the Contact sheet dialog starting in field "Width" using the "Tab" key, you find that the the field "Height" is not in the right tab order.
Effect: Irritating user interface
1. In XnView browser select one or several images
2. Select Tools » Create Contact sheet...
3. In "Create contact sheet" dialog right click into field "Width" to put input focus to that field.
4. Press Tab key twice
Actual behaviour (bug): Input focus is on field "DPI". Field "Height" is missed out. Tab order is wrong. :bug:
Expected behaviour: Input focus is on field "Height". Correct tab order.
Re: 0.85b2: Contact sheet: Field 'Height' in wrong tab order
This problem is supposed to be fixed in XnView MP 0.85 beta 3. Please check and confirm the bug fix here.
Tab order for field "Height" is confirmed fixed.
Though, tab order is still broken:
In panel "Color" the tab order is currently:
Text background colour > Text colour > Font > Filename > Format > Settings > Folder
Instead tab order should be:
Text background colour > Text colour > Font > Folder > Filename > Format > Settings
@Pierre: What is the status of this bug report?
helmut wrote:@Pierre: What is the status of this bug report?
changed in beta 4
changed in beta 4
Confirmed fixed in beta 4. Thank you, Pierre!
