Hi Pierre,
While testing the new Contact sheet, I noticed that settings where added to the INI file stored under a section with the name [DBClean].
Now the INI is your "responsibility" of course, but it seems like a strange name fot that section?
Regards,
Han
Contact sheet: INI section
Re: Contact sheet: INI section
This problem is supposed to be fixed in XnView MP 0.85 beta 3. Please check and confirm the bug fix here.
Tested with 0.85 beta 3, the ini section is now called [CSheet]. Fixed.
@Pierre: Thank you for the better name of the new section. Would you mind renaming the section [ContactSheet]? This would be even more meaningful and clearer.HanVroon wrote:Tested with 0.85 beta 3, the ini section is now called [CSheet]. Fixed.
okhelmut wrote:@Pierre: Thank you for the better name of the new section. Would you mind renaming the section [ContactSheet]? This would be even more meaningful and clearer.HanVroon wrote:Tested with 0.85 beta 3, the ini section is now called [CSheet]. Fixed.
