Contact sheet: Pressing Abort causes Crash
HanVroon
Post by HanVroon »
When pressing on Abort while the preview is created or the sheet file is created, XnViewMP stops working.
Re: Contact sheet: Pressing Abort causes Crash
This problem is supposed to be fixed in XnView MP 0.85 beta 3. Please check and confirm the bug fix here.
HanVroon
Post by HanVroon »
Tested in 0.85 beta 3, fixed.
Pressing abort in preview stops processing with a grey screen, looks OK.
Pressing abort in Create window (after pressing Create) ends the Create contact sheet proces, also looks OK.
