<Moderator's note: This topic has been moved>
I have a problem with the latest version of xnview.
My pictures, wich are turned before are not turned in the thumbnail browser window. In the preview window I can see them in the correctly displayed.
I couldn't find any setting about this thumbnail view.
Sorry for my bad english.
Thanks for help
Sunny
[Resolved] Thumbnails of turned pictures
Sunny
Thumbnails of turned pictures - problem solved
I installed the latest version and the problem is solved.
Sorry
Sunny
Sorry
Sunny
Re: Thumbnails of turned pictures - problem solved
Good to read that you could solve your problem. There's also an FAQ "How to rotate images automatically".Sunny wrote:I installed the latest version and the problem is solved
sbsaylors_
thumbnail doesnt match browser
My goodness I've done every possible option I've read - deleted the cache each time and still the thumbs wont match the pictures!
i 1.80.3. I've used ZIP lossless, jpg lossy (high/low). I've used the auto rotate, I've used reset EXIF, rotate based on. Change the read/write of jpg for EXIF.
PLEASE someone tell me I'm not crazy!
sbsaylors
thumbnail doesnt match browser - solved again <grin>
after much searching - it is ONE thing.
disable - "Use Embedded Thumbnails"
Enjoy
Enjoy
