XnView: MP 0.85b4 64 bit
OS: Windows 10 1607 64bit
Just the title.
Effect: Clipboard is erased when it should be independent from XnView.
1. Copy any image into the system clipboard. (As example press Print Screen key)
2. Close XnView.
Actual behaviour (bug): Clipboard has been erased. Try to paste it in any application and you'll notice your copied image is gone.
Expected behaviour: Clipboard contents should be maintained.
0.85b4: XnView clears system clipboard on exit
Re: 0.85b4: XnView clears system clipboard on exit
Thank you for your bug report. This a bit annoying bug has been reported before see topic http://newsgroup.xnview.com/viewtopic.php?t=25527 According to Pierre it's a problem in QT and Pierre is waiting for a bug fix.
Closed (Duplicate bug report)
