0.85 convert 48bit DNG results in 8bit ouput, XMP tags not exported to JXR
squeezechart
Post by squeezechart »
When this 48bit image is converted to PNG, TIFF, JPEG-XR, FLIF etc the output is always 8bit.
https://drive.google.com/file/d/0ByLIAF ... sp=sharing
Also, XMP tags are not exported when converting to JPEG-XR.
Re: 0.85 convert 48bit DNG results in 8bit ouput, XMP tags not exported to JXR
yes image is convert as 8bits per component. Only NConvert can convert 48bits to PNG, TIFF 48bits
xnview wrote:yes image is convert as 8bits per component. Only NConvert can convert 48bits to PNG, TIFF 48bits
O.k.. Is there a message box displayed that informs the user?
yes when you open it
0.85 convert 48bit DNG results in 8bit output, XMP tags not exported to JXR
O.k., so it's that XnView doesn't support 48bit images. Support of 48 bit images is a suggestion.
:arrow: Suggestions
squeezechart wrote:Also, XMP tags are not exported when converting to JPEG-XR.
As Pierre has pointed out XnView MP doesn't support XMP data in JXR files. There should be a message box informing the user that he/she will loose all metadata. I've created a separate bug report for this, see http://newsgroup.xnview.com/viewtopic.php?t=35429
sprayer
Post by sprayer »
Very sad, even to PNG 16bit per channel converting not working
