0.84-0.85 Del key does not work
Subjektiv
Post by Subjektiv »
In thumbnail view, list and details the Del-Taste does not work. But I can delete the pictures with right mouse context menu.
Im using Windows 10 and my keyboard works fine on all other programs.
Please can You fix it?
Re: 0.84-0.85 Del-Taste does not work
do you have checked in settings>Interface>shortcuts
Subjektiv
Re: 0.84-0.85 Del-Taste does not work SOLVED!
Post by Subjektiv »
Thank you and sorry for my stupidity!
I had deleted the matching shortcut...
Subjektiv wrote:...
Good to read that this issue is resolved. :)
If you want to reset all your shortcuts or toolbar buttons to default you can do this by simply removing the files default.bar (toolbar settings) and/or default.keys (keyboard settings). Location of config files can be determined by selecting button Open Config Files Location in Settings: Integration | Paths.
