NConvert 6.88 text_back bug
Vgqq
Post by Vgqq »
pic 1. Its a bug?
pic 2. Can you add a border like this in nconvert, please? :)
pic 3. When exporting scenario from xnconvert to nconvert occurs a bug with size of text and its colour. Can you fix it, please?
Re: Nconvert 6.88 text_back bug
You could try putting the -text "HELLO HELLO HELLO" term before the other text switches, i.e. immediately after the nconvert.exe term.
Just a guess though...
Note: If you post code, it would be helpful if you could post it between 'Code' tags:
C:\Users\xxxxx\Desktop\etc  ...
Vgqq wrote:pic 1. Its a bug?
i can't reproduce, your picture is RGB?
ok
yes will be fixed
Vgqq
Post by Vgqq »
cday, when i put text first:
nconvert.exe -text "HELLO HELLO HELLO" -text_font "Comic Sans MS" 32 -text_color 32 255 85 -text_back 0 0 0 -text_flag top-left -text_pos 20 420 -text_rotation 10 1.jpg
it gives me next:
xnview, I attaching image:
and code:
nconvert.exe -text_font "Comic Sans MS" 32 -text_color 32 255 85 -text_back 0 0 0 -text_flag top-left -text_pos 20 420 -text_rotation 10 -text "HELLO HELLO HELLO"
Can you reproduce it?
This bug occurs only with option "-text_rotation".
i can reproduce the bug
Vgqq
Post by Vgqq »
XnView How i can recognize, when it will be fixed? lt will be new digits in nconvert version on site or you inform about it on this forum? Sorry :)
Vgqq wrote:XnView How i can recognize, when it will be fixed? lt will be new digits in nconvert version on site or you inform about it on this forum? Sorry :)
yes version 7.00 available tomorrow...
Vgqq
Post by Vgqq »
xnview wrote:yes version 7.00 available tomorrow...
I downloaded. It works perfect! Thank you very much, your soft is the best :D
Vgqq
Post by Vgqq »
it's a bug with rotation :o
nconvert.exe -text_font "Comic Sans MS" 94 -text_color 255 85 0 -text_border 10 255 85 127 -text_back 0 0 0 -text_pos 90 280 -text_flag top-left -text_rotation 16 -text "HELLO HELLO HELLO" 1.jpg
yes currently it's a limitation
Vgqq
Post by Vgqq »
xnview wrote:yes currently it's a limitation
Oh, sorry. I will wait for the removal this limitation, can I?
Vgqq
Post by Vgqq »
And it's a difference in text rotation between nconvert and xnconvert: axis of rotation for xnconvert is center and nconvert's axis of rotation is top-left corner. Its make a problem for exporting scenario from xnconvert :?
Just for information.
I spent three hours covering women's charms, but it did not hide behind. :D
If the text and background with the outline are a fixed size, a workaround might be to create a small file with that content, convert the background to transparent, and then apply that image to your images using the NConvert watermark action...
Or, might it be simpler to use a freeware Windows software such as Paint.net which supports layers, and which would allow you to position the text on a transparent layer in front of the image using the mouse?
Vgqq
Post by Vgqq »
cday Thank you for your advices. I using preview xnconvert to prepare for a specific script(that uses nconvert) some parameters like offset x y and degree of rotation. I writing it to txt file for each picture. Then script processing some specific actions with photos. I can calculate this parameters(offsets and degree) by perambulating it in nconvert, but its uncofortable. Why not make nconvert and xnconvert prodused same result with same parameters? It will be great) sorry for my english :D
Vgqq
Post by Vgqq »
I writed my own programm, that does manipulation with text and image, and rotates text around its center. It has been easier than I thought :D :D Thanks.
