LoadIPTC & BeOS
matjako
LoadIPTC & BeOS
Post by matjako »
Hi, I am writing a photo-album type of an application for BeOS (R5) using GFL SDK v2.20. I have problems getting IPTC tags with LoadIPTC(). For instance, this will always return NumberOfItems ==0
        BPath path(&entref);
	GFL_IPTC_DATA *iptc;
	iptc = gflLoadIPTC(path.Path());
	if (iptc && iptc->NumberOfItems)
                //TODO...
the funny thing is GetIPTCData after LoadBitmap works! ??? Any ideas?
Re: LoadIPTC & BeOS
matjako wrote:Hi, I am writing a photo-album type of an application for BeOS (R5) using GFL SDK v2.20. I have problems getting IPTC tags with LoadIPTC(). For instance, this will always return NumberOfItems ==0
                //TODO...
Hum, the 2.20 has some problem with IPTC
Re: LoadIPTC & BeOS
Post by Guest »
xnview wrote: Hum, the 2.20 has some problem with IPTC
I see... this could be it :( I could get IPTC tags with GetIPTCData, of course, but I do not want to load a bitmap again, because I am using BeOS native image translators, so that would be 100% overhead.
