Unwanted file types shown in Viewer
Hacker
Post by Hacker »
Hi *.*,
For some reason it seems (after updating to 2.40 perhaps?) that in Viewer XnView is showing me file types I don't want it to show, like PDF's or icons in EXE files while browsing through a dir using Page Up / Down. Any ideas, please?
TIA
Roman
Re: Unwanted file types shown in Viewer
What are you settings in View → Filter By, Roman?
Hacker
Post by Hacker »
XnTriq,
It is set to Custom. The files are not shown in the Browser, only in the Viewer / Fullscreen.
Roman
Confirmed :bugconfirmed:
bg17aw
Post by bg17aw »
Hacker wrote:Hi *.*,
Roman
I have this issue too, really annoyed by the icons in exe files.
Any solution for this?
I can only reproduce if you have not Custom in browser. If i use Filter>Custom, PDF is not shown in viewer.
Hacker
Post by Hacker »
Pierre,
I can reproduce it with PDF or EXE when Filter set to Custom. Is there any way I can help reproduce?
Roman
Hacker wrote:Pierre,
please send me your xnview.ini
Hacker
Post by Hacker »
Pierre,
Sent to contact xnview com.
Roman
  1. Create a new folder (e.g. Test).
  2. Copy the following files into the newly-created folder:
    • XnViewMediaDetector.exe
    • A PDF file
  3. Start XnView v2.40.
  4. Deactivate Show item in view 'Thumbnails' for AI, PS, PDF files and All other files in Tools → Options... → File List → File List.
  5. Deactivate Recognize only by extension in Tools → Options... → File List → Misc. :!:
  6. Set View → View As to Thumbnails.
  7. Set View → Filter By to Custom.
  8. Point XnView's browser to X:\Test\.
  9. Open X:\Test\logo.png in XnView's non-fullscreen editor.
  10. Move through the folder by using the buttons for Previous file and Next file on the main toolbar.
    :bug: XnView opens the PNG and PDF file as well as the icon of the EXE.
the problem was with 'Recognize by ext', must be activated
    • A PDF file
  5. Activate Recognize only by extension in Tools → Options... → File List → Misc. :!:
if 'Recognize only by extension' is activated, i can't reproduce
xnview wrote:if 'Recognize only by extension' is activated, i can't reproduce
Sorry, Pierre, you're right. Of course it's the other way around:
  • The bug can only be reproduced if Recognize only by extension is deactived.
I've updated my previous post accordingly.
Hacker
Post by Hacker »
Not fixed in 2.41.
Roman
Hacker wrote:Not fixed in 2.41.
with 'Recognize only by extension' activated?
