Unwanted file types shown in Viewer
Hacker
Re: Unwanted file types shown in Viewer
Post by Hacker »
Recognize only by extension is turned off.
Roman
Hacker wrote:Recognize only by extension is turned off.
In next version
FileListUseExt=1
will resolve this issue
Hacker
Post by Hacker »
xnview wrote:In next version
FileListUseExt=1
Does this mean I will have to activate "Recognize only by extension" to solve this?
Roman
FileListUseExt=1
No, if you activate this setting, you can continue to disable "Recognize only by extension" (in next 2.43)
Hacker
Post by Hacker »
xnview wrote:No, if you activate this setting, you can continue to disable "Recognize only by extension" (in next 2.43)
OK Pierre, thank you, will test. What does the setting do? Also why do we need a setting to fix what has worked before (and stopped working recently)? I must be missing something.
Roman
there was a fix for this problem
Hacker
Post by Hacker »
Yay, fixed in 2.43, thank you!
Roman
Is FileListUseExt a UI-less setting, and if so, in which section does it belong?
Mr Wolf
Post by Mr Wolf »
Hi, I'm having the same issue, even with the latest version (Windows 7 64 bit): if, for example, I open images on the desktop and go back/forward, XnView opens the icons in the program shortcuts, or it opens videos even if I excluded them from the list of the files to open.
The only solution is to flag "Recognize only by extension" on.
This issues was not present in the previous versions.
Where should FileListUseExt=1 be put in the ini config file?
Mr Wolf wrote: Where should FileListUseExt=1 be put in the ini config file?
in [Browser] section
Mr Wolf
Post by Mr Wolf »
Ok, it works! :D
Thanks!
